Hilfe durchsuchen
Vorsicht vor Support-Betrug: Wir fordern Sie niemals auf, eine Telefonnummer anzurufen, eine SMS an eine Telefonnummer zu senden oder persönliche Daten preiszugeben. Bitte melden Sie verdächtige Aktivitäten über die Funktion „Missbrauch melden“.
Weitere Informationen
how to migrate address book from thunderbird to outlook?
  • 3 Antworten
  • 2 haben dieses Problem
  • 6 Aufrufe
  • Letzte Antwort von jcena5613
yesterday i used a tool for migrating my data from thunderbird to ms outlook. i used this utility https://www.spikevare.com/thunderbird/, but the problem is when i migrate data from Thunderbird to outlook address book did not migrated because this software converts mbox to pst. i exported my address book in csv file format but there is no option available in outlook to import csv file. can anyone help me to import my exported address book from thunderbird to outlook 2013.
please help me this is very urgent for me because i am not able to access my address book and i have more than 2000 contacts. every time i need to check from my excel file and copy paste each contact that is time consuming
yesterday i used a tool for migrating my data from thunderbird to ms outlook. i used this utility https://www.spikevare.com/thunderbird/, but the problem is when i migrate data from Thunderbird to outlook address book did not migrated because this software converts mbox to pst. i exported my address book in csv file format but there is no option available in outlook to import csv file. can anyone help me to import my exported address book from thunderbird to outlook 2013. please help me this is very urgent for me because i am not able to access my address book and i have more than 2000 contacts. every time i need to check from my excel file and copy paste each contact that is time consuming
Alle Antworten (3)
You can read how to import csv files to Outlook, and map custom fields, on this page.
thanks problem solved :)
Yes you can import csv file into outlook easily, if you are not familiar with steps you can use third party tools. There are multiple companies that offers csv to vcard that can easily import into outlook. Check this article, this will help you to migrate csv to vcard file format. http://download.cnet.com/Softaken-CSV-to-VCard-Converter/3000-2248_4-77472943.html
